Presentez HRD RPE
Welxome, you will find it for sure ! Do you have some pictures of your bikes please?
I'm a little late. Here are my bikes:
HRD RPE 80 Competition with Minarelli K6
HRD RPE 80 Competition with Casal M117 and GS Fork/Shocks
Modifié en dernier par hrd rpe le 30 nov. 2011 10:44, modifié 1 fois.
Looking for everything on HRDs, Parst, Literature, Bikes
What about the CASAL Engine, we don't know it in France?
Yes, there was the M117 with a Bing 21 carburator , the tame version with 10 HP and the M118 with the HuVo Cylinder , 28 or 30 mm Del'Orto and up to 21 HP. Both engines are hard to find in Germany. Of course, the M118 more difficult than the M117.
A friends bike with the M118 with a Huvo cylinder:
its the 50cc , with 40x40mm, but for this model we stil have almost everything , and with the huvo 48piston , or the brand new italkit , polini or malossi in 54 and 55 or 57 , it becames strong , and crankshaft its calibrate for 12500rpm , and the m117 or m118 its not calibrate for so hig rpm, so the broke more , thats way hrd , and other brands start only to buy minarelli mr80
in out side look , the m105 are the same of the m117 , only the cylinder is taller almost 1cm , the m112 are the some looking , but have de kickstart in the lef side, but inside its the same of al 3 models , and you can change the gear box , and other internal pieces in the 3 models too
Modifié en dernier par norttee le 01 déc. 2011 18:43, modifié 1 fois.
