175 Rebuild
ENDURO CROSS TRIAL
hm450
Message par hm450 »
A white OEM headlight would be appreciated...Good Job and congratulations :)
A pic made at a flea market in Italy, in order to show you as it could be
Uploaded with ImageShack.us
Modifié en dernier par hm450 le 01 juin 2011 16:38, modifié 1 fois.
rech repose pieds passagers origine Hm
NSR
Message par NSR »
You should change the headmask i think.
Yes, I think you are right.
Thanks Martin.
Sunshine Coast
Australia
MotoSWM
Message par MotoSWM »
Hi Noel
I found out on another site that a 250 Kramer with a Rotax motor was fitted with a Mikuni from standard, the jet sizes are :-
Carb Diameter 34
Needle 6DH7
Jet max 279
Idle jet 35
Slide 2,5
Atomiser jet 159-P8
So slide, pilot and main should be about right....just the needle/atomiser different
Hope this helps
Martin
Good job, congratulations! You should change the headmask i think.
NSR
Message par NSR »
It is two weeks until Classic Dirt, As I am helping organize it I will not have time to do any setup on my bike.
So I would like to ask this question again.
C'est de deux semaines jusqu'à la saleté classique, car j'aide l'organise que je n'aurai pas le temps pour ne faire aucune installation sur mon vélo. Ainsi je voudrais poser cette question encore.
I have installed a new 34 Mikuni. J'ai installé un nouveau 34 Mikuni.
The settings are:
Main jet 260
Idle jet 35
Needle 6DH4
Slide 2.5
Are these settings close for a Rotax 175? Sont ces paramètres près de 175 Rotax?
Cheers
Noel
Sunshine Coast
Australia
fast and so nice result :cool:
congratulations , i like it !! ;)
NSR
Message par NSR »
Almost finished ;)
Modifié en dernier par NSR le 23 avr. 2011 14:34, modifié 1 fois.
Sunshine Coast
Australia
NSR
Message par NSR »
The settings are:
Main jet 260
Idle jet 35
Needle 6DH4
Slide 2.5
Cheers
Noel
Sunshine Coast
Australia
NSR a écrit :
What color did you choose for the frame?
The color was matched by the paint shop.
When I got the bike it came with a box of spares, in the box was 5 47T sprockets but they were for the bigger SWMs so they were 525 or 530 :quoi:.
[img_citation]http://www.srcf.fr/forum/img_forum/2011/02/097.JPG[/img_citation]
I have had one turned down to fit a 520 chain,
[img_citation]http://www.srcf.fr/forum/img_forum/2011/02/090.JPG[/img_citation]
Do you put grease on the drive rubbers If yes what type? I got 52 of these with the bike :D
[img_citation]http://www.srcf.fr/forum/img_forum/2011/02/157.JPG[/img_citation]
Non, pas de graisse sur les caoutchouc, surtout pas de graisse de base pétrolière. Les caoutchouc ne vont pas supporter.
La graisse risque de s'amalgamer avec la poussière et se transformer en pâte à roder.
Modifié en dernier par Swoum_55 le 18 févr. 2011 16:08, modifié 1 fois.
NSR
Message par NSR »
Sunshine Coast
Australia
Very good job Noël! What color did you choose for the frame?
NSR
Message par NSR »
Sunshine Coast
Australia
NSR
Message par NSR »
My rebuilds still going.
I have had the alloy hydrablasted and the spokes and bolts plated.
NOS chain guide and new plates.
I have given the shocks an upgrade.
Cheers
Noel
Sunshine Coast
Australia
NSR
Message par NSR »
I think I understand :mick I have heard of it.
Je crois que je comprends: mick j'ai entendu parler de lui. :/
I have taken the clutch apart, hoping to make the pull lighter :hein:
J'ai pris l'embrayage en dehors, dans l'espoir de rendre le pull léger :/
I will have the surface machined smooth were the bearings run.
Je vais devoir la surface usinée lisse ont été les paliers de l'exécution.
Sunshine Coast
Australia
