The Lens looks like this with clear bottom like this and "case" looks like : https://img4.annuncicdn.it/b4/10/b410f8 ... 6_orig.jpg
I found plenty of Cev 174 lamps but not even one 203 with clear bottom (same lamp only differeces being, 203 has brake light and clear bottom) And iam sure there is Cev 203 Lamp looks like this
: https://cdn.nettivaraosa.com/live/24482 ... -large.jpg
CEV 203 tail light
- Nouveau Squadriste
Modifié en dernier par Kalle from finland le 08 déc. 2017 02:34, modifié 1 fois.
http://foggia.bakeca.it/dettaglio/ricam ... x131975270
http://bologna.bakeca.it/dettaglio/rica ... 7123037612
Ciao io sono nuovo qui e non so se la mia domanda qui.
Sto cercando vecchio, CEV 203 del fanale posteriore, in cui la parte inferiore della piastra di licenza è luce. Ma non so dove trovare una cosa del genere. Quindi ho bisogno di aiuto per trovare la luce
In English. Hi, iam looking for old tail light for my moped Model is Cev 203 (i guess), with clear lens under for registeration plate light. Lamp is like CEV 174 but lens is bit thicker and has clear bottom. So if you know where to get one could you link it! Thanks for help! -Kalle
