Marzocchi 40mm USD seals?
jamba
Message par jamba »
Good tip NSR :)
NSR
Message par NSR »
Jamba
I am using 15wt fork oil in the compression side and 10wt in the rebound. 90mm from the top. Seems good, I need to do a bit more riding on it.
Sunshine Coast
Australia
jamba
Message par jamba »
THANK YOU!!!
You're the man, NSR :) :) :) :)
-jamba
NSR
Message par NSR »
This is the photo I meant to post.
Sunshine Coast
Australia
jamba
Message par jamba »
Thank you!!!
Would you know code for dust seals, too?
These Ari.063 i can get easily now :)
NSR
Message par NSR »
These are the seals I used in my Kram-it forks. They also make the dust seal.
Sunshine Coast
Australia
jamba
Message par jamba »
Ok. I will do that immediately :)
Here you are:
http://www.srcf.fr/forum/t6838-Puch-Frigerio.html
Modifié en dernier par jamba le 09 déc. 2015 16:47, modifié 1 fois.
Hello Jamba. If you need some help, it should be kind of you to create a topic about the restoration of your Puch? Then we could see the pictures......thanks. :cool:
jamba
Message par jamba »
Hi!
Once again i need your advice...
My -89 Puch 250 F7 has Marzocchi 40mm USD front suspension. Same suspension is on -89 KTM 250 and Kramit 250.
I found this exellent pdf file showing how to do maintenance for it:
http://dirtypart.com/manuals/filer/KTM/ ... Gaffel.PDF
But i'm confused a bit as i don't really know where to get dust seals and oil seals to it. There seems to be never 40mm Marzocchi fork seals on market, but i don't know if they fit. Could someone inform me for correct part numbers so i could start searching or a link to company where to buy online?
rough translation:
Une fois de plus je besoin de vos conseils ...
Mon -89 Puch 250 F7 a Marzocchi 40mm USD suspension avant. Même suspension est sur -89 KTM 250 et 250 Kramit.
Je trouve ce fichier pdf exellent montrant comment faire l'entretien pour elle:
Mais je suis un peu confus que je ne sais vraiment pas où obtenir joints antipoussière et joints d'huile à elle. Il semble y avoir jamais 40mm fourche Marzocchi sur phoques marché, mais je ne sais pas si elles correspondent. Quelqu'un pourrait-il me renseigner pour les références correctes pour que je puisse commencer la recherche ou un lien à la société où acheter en ligne?
