1970>1985 CROSS ENDURO
jodygibbons
Message
par jodygibbons »
jmb a écrit :jodygibbons a écrit :jmb a écrit :
You re welcome.
they should have and prices are very cheap :clin:
That's great to hear
thanks JMB
for the 200 , 6 euro......
That is cheap - I would look to get several like that
Bikes: Cagiva RX250, Cagiva MXR250, Cagiva WMX500
jodygibbons
Message
par jodygibbons »
jmb a écrit :and still works even batterie is dead
This is true. The battery wouldn't last 40years like this
jodygibbons
Message
par jodygibbons »
GAUTHIERBMX a écrit :your dad one is clearly better for our old bike
More in keeping
Message
par jmb »
jodygibbons a écrit :jmb a écrit :jodygibbons a écrit :
Thank you jmb - I will check them out
Many Thanks
Jody
You re welcome.
thanks JMB
Message
par jmb »
GAUTHIERBMX
Message
par GAUTHIERBMX »
Forza CAGIVA
jodygibbons
Message
par jodygibbons »
GAUTHIERBMX a écrit :hello jody
you must change your beautiful digital caliper
jean
Yes I know - it is a little tired and needs a clean up! It was my dad's old one. A digital one would probably be easier
Modifié en dernier par
jodygibbons le 03 août 2021 17:19, modifié 1 fois.
jodygibbons
Message
par jodygibbons »
Many Thanks
Jody
You re welcome.
thanks JMB
GAUTHIERBMX
Message
par GAUTHIERBMX »
hello jody
jean
Forza CAGIVA
Message
par jmb »
Many Thanks
Jody
You re welcome.
jodygibbons
Message
par jodygibbons »
Thank you Didier
that looks perfect! I will look to contact them.
Many Thanks
Jody
jodygibbons
Message
par jodygibbons »
Many Thanks
Jody
Message
par didier 06 »
contact " pistoni gol " they have
as you can see it's ok for original mahle piston
Message
par jmb »
hello !
try there...
https://www.thn.fr/ :clin:
jodygibbons
Message
par jodygibbons »
Good evening all,
I was trying to obtain a new piston ring (or several) for my Mahle piston which runs in a 1980 Cagiva RX250 enduro motorcycle.
It measures as follows:
Ring outer diameter: 74.8mm
Ring inner diameter: 69mm
Ring width: 3mm
Ring thickness: 1.5mm
I have attached photos showing measurements and the cutout for the pin in the piston.
Any help would be very much appreciated.
Many Thanks
Jody
